Ga door naar hoofdinhoud
Creative Ziio 7" LCD Screen Replacement
Wat je nodig hebt
  1. Creative Ziio 7" LCD Screen Replacement, Back Panel: stap 1, afbeelding 1 van 3 Creative Ziio 7" LCD Screen Replacement, Back Panel: stap 1, afbeelding 2 van 3 Creative Ziio 7" LCD Screen Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
  2. Creative Ziio 7" LCD Screen Replacement, LCD Screen: stap 2, afbeelding 1 van 1
    • Remove the four 3mm Philips #00 screws around the large silver battery.
  3. Creative Ziio 7" LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Remove the four 4mm Philips #00 screws on the edges of the circuit board.
  4. Creative Ziio 7" LCD Screen Replacement: stap 4, afbeelding 1 van 3 Creative Ziio 7" LCD Screen Replacement: stap 4, afbeelding 2 van 3 Creative Ziio 7" LCD Screen Replacement: stap 4, afbeelding 3 van 3
    • Remove the ribbon cable from the exposed side of circuit board near the headphone jack.
    • Carefully lift up the circuit board on the detached side.
    • There is another ribbon cable attached to the underside of the circuit board.
    • Disconnect the second ribbon cable by pulling the end of the ribbon from its housing on the circuit board with tweezers.
    • The circuit board is extremely delicate. Move carefully and don't rush on this step!
  5. Creative Ziio 7" LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • On the opposite end of the device: Remove the ribbon cable in between the speakers at the end of the battery.
  6. Creative Ziio 7" LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • There are three additional 3mm Philips #00 screws underneath the circuit board that need to be removed.
    • Now, remove the battery and circuit board with the LCD attached and turn it over so the screen is facing upwards.
  7. Creative Ziio 7" LCD Screen Replacement: stap 7, afbeelding 1 van 2 Creative Ziio 7" LCD Screen Replacement: stap 7, afbeelding 2 van 2
    • Carefully pry the thin, metal frame from around the LCD screen.
    • The frame is extremely thin! Take your time when removing it to avoid bending or deforming it.
  8. Creative Ziio 7" LCD Screen Replacement: stap 8, afbeelding 1 van 1
    • Carefully remove the black LCD screen.
Conclusie
Kyle
120 Reputatie
2 handleidingen geschreven
Cal Poly, Team 14-10, Maness Spring 2013 Lid van Cal Poly, Team 14-10, Maness Spring 2013
CPSU-MANESS-S13S14G10
4 Leden
13 handleidingen geschreven
2 opmerkingen
Where can I buy Creative Ziio 7" LCD Scren?
CoolBlazer - Antwoord
i need LCD Creative Labs ZIIO 7 Inch Tablet, where i can buy?... please help me... thx before...
irawansandra -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 12
Altijd: 1,364
