Inleiding
This guide will show you how to remove and install a new LCD screen in your device. Use this guide if your screen is broken or damaged and needs to be replaced.
Wat je nodig hebt
Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
Use a spudger to separate the metal tabs that hold the screen in place on the right side.
Één andere persoon heeft deze handleiding voltooid.
