Ga door naar hoofdinhoud
Creative Zen Vision W Keypad Replacement
Wat je nodig hebt
  1. Creative Zen Vision W Keypad Replacement, Front Cover: stap 1, afbeelding 1 van 2 Creative Zen Vision W Keypad Replacement, Front Cover: stap 1, afbeelding 2 van 2
    • Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
  2. Creative Zen Vision W Keypad Replacement: stap 2, afbeelding 1 van 3 Creative Zen Vision W Keypad Replacement: stap 2, afbeelding 2 van 3 Creative Zen Vision W Keypad Replacement: stap 2, afbeelding 3 van 3
    • Run the spudger along the cover and pry.
    • Do this gently to preserve the screen
    • The button pad may fall off when the cover is removed.
  3. Creative Zen Vision W Keypad Replacement, LCD Screen: stap 3, afbeelding 1 van 3 Creative Zen Vision W Keypad Replacement, LCD Screen: stap 3, afbeelding 2 van 3 Creative Zen Vision W Keypad Replacement, LCD Screen: stap 3, afbeelding 3 van 3
    • Use a spudger to separate the metal tabs that hold the screen in place on the right side.
    • The screen is still attached underneath with two ribbon cables. Lift it very carefully.
  4. Creative Zen Vision W Keypad Replacement: stap 4, afbeelding 1 van 1
    • Put the screen face down so you can see where the ribbon cables are attached.
    • Remove the red sticker that covers the ribbon cable connections.
  5. Creative Zen Vision W Keypad Replacement: stap 5, afbeelding 1 van 1
    • Use a plastic opening tool to get underneath the black flap on the larger ribbon cable connection and lift it.
  6. Creative Zen Vision W Keypad Replacement: stap 6, afbeelding 1 van 3 Creative Zen Vision W Keypad Replacement: stap 6, afbeelding 2 van 3 Creative Zen Vision W Keypad Replacement: stap 6, afbeelding 3 van 3
    • Use a spudger to slide the two small gray tabs away from the ribbon cable connection.
    • Remove the screen from the device.
  7. Creative Zen Vision W Keypad Replacement, Keypad: stap 7, afbeelding 1 van 1
    • Peel the orange sticker off of the motherboard.
  8. Creative Zen Vision W Keypad Replacement: stap 8, afbeelding 1 van 2 Creative Zen Vision W Keypad Replacement: stap 8, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Lift the keypad from the left side and use tweezers to slide it out to the left.
  9. Creative Zen Vision W Keypad Replacement: stap 9, afbeelding 1 van 2 Creative Zen Vision W Keypad Replacement: stap 9, afbeelding 2 van 2
    • Use a small flat head screw driver to slide the white tabs away from the ribbon cable connection.
    • Remove the ribbon cable from the keypad.
Conclusie
Tim Wilson
143 Reputatie
6 handleidingen geschreven
Cal Poly, Team 17-2, Regan Spring 2013 Lid van Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 427
