Ga door naar hoofdinhoud
Creative Zen Vision W Hard Drive Replacement
Wat je nodig hebt
  1. Creative Zen Vision W Hard Drive Replacement, Battery Removal: stap 1, afbeelding 1 van 3 Creative Zen Vision W Hard Drive Replacement, Battery Removal: stap 1, afbeelding 2 van 3 Creative Zen Vision W Hard Drive Replacement, Battery Removal: stap 1, afbeelding 3 van 3
    • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
  2. Creative Zen Vision W Hard Drive Replacement, Back Cover: stap 2, afbeelding 1 van 1
    • Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
  3. Creative Zen Vision W Hard Drive Replacement: stap 3, afbeelding 1 van 2 Creative Zen Vision W Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Remove the 5 screws (5.5 mm), circled in red, using a Phillips #0. Use a flashlight if necessary.
    • Peel off the sticker that says "Creative warranty void if broken" and remove the screw (5.5 mm) underneath with a Phillips #0.
    • Be careful, some of the screws are difficult to see and can be easily stripped.
  4. Creative Zen Vision W Hard Drive Replacement: stap 4, afbeelding 1 van 3 Creative Zen Vision W Hard Drive Replacement: stap 4, afbeelding 2 van 3 Creative Zen Vision W Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Carefully pull the back cover off of the rest of the device.
    • The volume control buttons and power slider may fall off when removing the cover, do not lose these small pieces.
    • The USB input cover on the bottom of the device may also fall off.
  5. Creative Zen Vision W Hard Drive Replacement, Hard Drive: stap 5, afbeelding 1 van 2 Creative Zen Vision W Hard Drive Replacement, Hard Drive: stap 5, afbeelding 2 van 2
    • Remove 4 screws (3.5 mm) on the metal cover with a Phillips #0.
    • Lift the metal cover off.
  6. Creative Zen Vision W Hard Drive Replacement: stap 6, afbeelding 1 van 3 Creative Zen Vision W Hard Drive Replacement: stap 6, afbeelding 2 van 3 Creative Zen Vision W Hard Drive Replacement: stap 6, afbeelding 3 van 3
    • Lift the white and black ribbon connection off of the motherboard.
    • The hard drive can now be removed.
Conclusie
Tim Wilson
143 Reputatie
6 handleidingen geschreven
Cal Poly, Team 17-2, Regan Spring 2013 Lid van Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 43
Altijd: 3,709
