Ga door naar hoofdinhoud
Creative Zen Vision M Screen Replacement
Wat je nodig hebt
  1. Creative Zen Vision M Screen Replacement, Opening the top: stap 1, afbeelding 1 van 2 Creative Zen Vision M Screen Replacement, Opening the top: stap 1, afbeelding 2 van 2
    • Pop off the top plastic on the device with a flat tool like a flathead screwdriver.
    • Unscrew and remove the two exposed Phillips head screws.
  2. Creative Zen Vision M Screen Replacement, Opening the device: stap 2, afbeelding 1 van 2 Creative Zen Vision M Screen Replacement, Opening the device: stap 2, afbeelding 2 van 2
    • Work your way around the recess of the device with a flat tool like a flathead screwdriver.
    • Don't try attempt to open it from the recess between the buttons and the device.
  3. Creative Zen Vision M Screen Replacement, Disconnecting the battery: stap 3, afbeelding 1 van 3 Creative Zen Vision M Screen Replacement, Disconnecting the battery: stap 3, afbeelding 2 van 3 Creative Zen Vision M Screen Replacement, Disconnecting the battery: stap 3, afbeelding 3 van 3
    • Disconnect the wire from the bottom device.
    • Handle with care as the wires tend to disconnect easily.
  4. Creative Zen Vision M Screen Replacement, Disconnecting the hard drive: stap 4, afbeelding 1 van 1
    • In the top right corner, pull the black foam square off to separate the hard drive from the screen.
    • Handle with care as the hard drive also comes off easily.
  5. Creative Zen Vision M Screen Replacement, Unscrewing from the mother board: stap 5, afbeelding 1 van 1
    • Unscrew the seven screws placed around the mother board.
    • You will need a one millimeter Phillips head screwdriver.
    • The screws are small, so keep them safely.
  6. Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: stap 6, afbeelding 1 van 3 Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: stap 6, afbeelding 2 van 3 Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: stap 6, afbeelding 3 van 3
    • Flip your device upside down so that the motherboard will loosen.
    • Detach the connector from the motherboard.
  7. Creative Zen Vision M Screen Replacement, Removing the screen: stap 7, afbeelding 1 van 2 Creative Zen Vision M Screen Replacement, Removing the screen: stap 7, afbeelding 2 van 2
    • Tilt the screen diagonally. Separate the screen and motherboard from the device frame.
    • Lift the light gray flap to detach the screen from the motherboard.
  8. Creative Zen Vision M Screen Replacement, Seperating the digital display: stap 8, afbeelding 1 van 2 Creative Zen Vision M Screen Replacement, Seperating the digital display: stap 8, afbeelding 2 van 2
    • Separate the clear screen frame from the digital display.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kirstie G
488 Reputatie
4 handleidingen geschreven
Texas Tech, Team 12-1, Bennett Fall 2016 Lid van Texas Tech, Team 12-1, Bennett Fall 2016
TTU-BENNETT-F16S12G1
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 42
Altijd: 1,733
