Ga door naar hoofdinhoud
Creative Zen V Plus Logic Board Replacement
Wat je nodig hebt
  1. Creative Zen V Plus Logic Board Replacement, Prerequisite Only: stap 1, afbeelding 1 van 1
    • Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
  2. Creative Zen V Plus Logic Board Replacement: stap 2, afbeelding 1 van 1
    • Using a plastic opening tool, place the skinny flat end between the groove running along side of the device.
    • Using a twisting motion, detach the control panel from the device
  3. Creative Zen V Plus Logic Board Replacement: stap 3, afbeelding 1 van 1
    • Find the groove around the outside of the green section. Use an ESD safe spudger to slowly lift the plastic panel up.
  4. Creative Zen V Plus Logic Board Replacement: stap 4, afbeelding 1 van 2 Creative Zen V Plus Logic Board Replacement: stap 4, afbeelding 2 van 2
    • After removing the green section, find the groove around the display. Insert a ESD safe spudger and carefully lift the display.
  5. Creative Zen V Plus Logic Board Replacement: stap 5, afbeelding 1 van 1
    • The display can lift up the display but be sure not to damage any of the cables connecting it to the mother board.
    • Remove the screw located under the display using the 00 Phillips head screwdriver.
  6. Creative Zen V Plus Logic Board Replacement: stap 6, afbeelding 1 van 3 Creative Zen V Plus Logic Board Replacement: stap 6, afbeelding 2 van 3 Creative Zen V Plus Logic Board Replacement: stap 6, afbeelding 3 van 3
    • Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
  7. Creative Zen V Plus Logic Board Replacement, Logic Board: stap 7, afbeelding 1 van 1
    • Unplug the logic board from the battery. Replace the logic board with your new logic board and reassemble your device.
Conclusie
Joel Ng
245 Reputatie
1 Handleiding geschreven
IUPUI, Team 2-5, Baechle Fall 2016 Lid van IUPUI, Team 2-5, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G5
4 Leden
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 634
