Ga door naar hoofdinhoud
Creality Ender 3 V2 Extruder Nozzle Replacement
Wat je nodig hebt
  1. Creality Ender 3 V2 Extruder Nozzle Replacement, Extruder Nozzle: stap 1, afbeelding 1 van 1
    • Move the extruder carriage to the center of the machine.
  2. Creality Ender 3 V2 Extruder Nozzle Replacement: stap 2, afbeelding 1 van 1
    • Use a 2 mm Allen wrench to remove the two screws located on the back of the extruder shroud.
  3. Creality Ender 3 V2 Extruder Nozzle Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the shroud by pulling it away from the hot end of the 3D printer.
  4. Creality Ender 3 V2 Extruder Nozzle Replacement: stap 4, afbeelding 1 van 3 Creality Ender 3 V2 Extruder Nozzle Replacement: stap 4, afbeelding 2 van 3 Creality Ender 3 V2 Extruder Nozzle Replacement: stap 4, afbeelding 3 van 3
    • Remove the silicon sleeve around the heat block.
    • Before removing the nozzle, you must bring the printer up to operating temperature in order to remove the leftover filament from the extruder.
  5. Creality Ender 3 V2 Extruder Nozzle Replacement: stap 5, afbeelding 1 van 2 Creality Ender 3 V2 Extruder Nozzle Replacement: stap 5, afbeelding 2 van 2
    • Once the excess filament has been removed, loosen the nozzle by a quarter turn using the wrench provided, then either power off or cool down the printer.
    • Do not attempt to fully remove the nozzle while the printer is at operating temperature. Allow the nozzle to fully cool before removal.
  6. Creality Ender 3 V2 Extruder Nozzle Replacement: stap 6, afbeelding 1 van 3 Creality Ender 3 V2 Extruder Nozzle Replacement: stap 6, afbeelding 2 van 3 Creality Ender 3 V2 Extruder Nozzle Replacement: stap 6, afbeelding 3 van 3
    • Before removing the nozzle check the temperature by bringing the back of your hand near the nozzle; do not touch it. If you feel any heat on the back of your hand, then wait another 10-15 minutes before removing the nozzle.
    • If the nozzle is fully cooled, remove the nozzle.
  7. Creality Ender 3 V2 Extruder Nozzle Replacement: stap 7, afbeelding 1 van 2 Creality Ender 3 V2 Extruder Nozzle Replacement: stap 7, afbeelding 2 van 2
    • Screw on the new nozzle into the heat block with your wrench.
    • To fully tighten the nozzle, bring the printer back to operating temperature and do a final tightening of the nozzle.
    • Printer must be at operating temperature when fully tightening in order to prevent leaks in the future.
Conclusie
Print away!
7 andere personen hebben deze handleiding voltooid.
Marc-Anthony Cardoso
235 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 86
Afgelopen 30 dagen: 440
Altijd: 19,027
