Ga door naar hoofdinhoud
Craig Electronics CMP773 Volume/Power Control Button Replacement
Wat je nodig hebt
  1. Craig Electronics CMP773 Volume/Power Control Button Replacement, Volume/Power Control Button: stap 1, afbeelding 1 van 1
    • Remove the two 3.2 mm PH000 screws near the charging port.
  2. Craig Electronics CMP773 Volume/Power Control Button Replacement: stap 2, afbeelding 1 van 1
    • Pry the back cover from the device along bottom edge.
  3. Craig Electronics CMP773 Volume/Power Control Button Replacement: stap 3, afbeelding 1 van 1
    • Continue prying along each edge of the device until back cover is free.
  4. Craig Electronics CMP773 Volume/Power Control Button Replacement: stap 4, afbeelding 1 van 1
    • On the back cover, find the location where the volume/power button is held.
    • The volume/power button is not held securely after back is removed so it may fall out of place while removing the back cover from the device.
  5. Craig Electronics CMP773 Volume/Power Control Button Replacement: stap 5, afbeelding 1 van 2 Craig Electronics CMP773 Volume/Power Control Button Replacement: stap 5, afbeelding 2 van 2
    • Remove the old button and replace it with the new one.
Conclusie
Once the above steps have been successfully competed, power on the device. Enjoy your newly replaced volume/power control button.
Jessie L Morris
171 Reputatie
1 Handleiding geschreven
IUPUI, Team S1-G5, Harley Spring 2018 Lid van IUPUI, Team S1-G5, Harley Spring 2018
IUPUI-HARLEY-S18S1G5
6 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 172
