Ga door naar hoofdinhoud
Craig Electronics CMP773 Screen Replacement
Wat je nodig hebt
  1. Craig Electronics CMP773 Screen Replacement, Screen: stap 1, afbeelding 1 van 2 Craig Electronics CMP773 Screen Replacement, Screen: stap 1, afbeelding 2 van 2
    • Remove two screws on the charging port side of the tablet using the Phillips #00 screwdriver.
  2. Craig Electronics CMP773 Screen Replacement: stap 2, afbeelding 1 van 3 Craig Electronics CMP773 Screen Replacement: stap 2, afbeelding 2 van 3 Craig Electronics CMP773 Screen Replacement: stap 2, afbeelding 3 van 3
    • Insert a plastic opening tool between the screen and the back of the tablet.
    • Insert another opening tool along the same side of the tablet and pry them in opposite directions until the casing pops.
    • Once roughly half of the case has been unlatched, it can be removed by hand.
  3. Craig Electronics CMP773 Screen Replacement: stap 3, afbeelding 1 van 2 Craig Electronics CMP773 Screen Replacement: stap 3, afbeelding 2 van 2
    • Use the spudger to gently pry the camera from the casing.
  4. Craig Electronics CMP773 Screen Replacement: stap 4, afbeelding 1 van 2 Craig Electronics CMP773 Screen Replacement: stap 4, afbeelding 2 van 2
    • Using your finger, remove the clamp that connects the screen power rib to the motherboard.
    • Using needle nose pliers, remove the ribbon.
  5. Craig Electronics CMP773 Screen Replacement: stap 5, afbeelding 1 van 3 Craig Electronics CMP773 Screen Replacement: stap 5, afbeelding 2 van 3 Craig Electronics CMP773 Screen Replacement: stap 5, afbeelding 3 van 3
    • Remove the second screen power connection from the motherboard using the same procedure as step 4.
  6. Craig Electronics CMP773 Screen Replacement: stap 6, afbeelding 1 van 3 Craig Electronics CMP773 Screen Replacement: stap 6, afbeelding 2 van 3 Craig Electronics CMP773 Screen Replacement: stap 6, afbeelding 3 van 3
    • Remove four screws from the motherboard using the Phillips #00 screwdriver.
  7. Craig Electronics CMP773 Screen Replacement: stap 7, afbeelding 1 van 2 Craig Electronics CMP773 Screen Replacement: stap 7, afbeelding 2 van 2
    • Remove a single screw from the speaker using the Phillips #00 screwdriver.
    • Pry up on the locking tabs with the flat spudger.
  8. Craig Electronics CMP773 Screen Replacement: stap 8, afbeelding 1 van 1
    • Using needle nose pliers, remove the ground wire from the casing.
  9. Craig Electronics CMP773 Screen Replacement: stap 9, afbeelding 1 van 1
    • Using the plastic opening tool, remove the battery.
  10. Craig Electronics CMP773 Screen Replacement: stap 10, afbeelding 1 van 2 Craig Electronics CMP773 Screen Replacement: stap 10, afbeelding 2 van 2
    • With all screws and components removed, gently remove the motherboard from the casing.
  11. Craig Electronics CMP773 Screen Replacement: stap 11, afbeelding 1 van 3 Craig Electronics CMP773 Screen Replacement: stap 11, afbeelding 2 van 3 Craig Electronics CMP773 Screen Replacement: stap 11, afbeelding 3 van 3
    • Insert the spudger in between the screen and case. Work your way around the outside of the screen.
  12. Craig Electronics CMP773 Screen Replacement: stap 12, afbeelding 1 van 3 Craig Electronics CMP773 Screen Replacement: stap 12, afbeelding 2 van 3 Craig Electronics CMP773 Screen Replacement: stap 12, afbeelding 3 van 3
    • Grasp the exposed screen corner and gently separate the screen from the housing.
Conclusie
Justin mersch
205 Reputatie
1 Handleiding geschreven
IUPUI, Team S3-G4, Harley Fall 2019 Lid van IUPUI, Team S3-G4, Harley Fall 2019
IUPUI-HARLEY-F19S3G4
4 Leden
3 handleidingen geschreven
Één opmerking
What kind of battery does this device specifically use
Kris Miller - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 211
