Inleiding
If the camera on your Craig Electronics CMP773 Tablet is scratched, damaged, or malfunctioning for any reason, you may find yourself needing to replace it. This guide will lead you through replacing the camera unit on your tablet. Note that the front and rear cameras are attached to the same electronic circuit, so the replacement part is just one unit for both cameras.
Wat je nodig hebt
Remove the two Phillips #00 screws from the bottom of the screen.
