Ga door naar hoofdinhoud
Craig Electronics CMP773 Front and Rear Camera Replacement
Wat je nodig hebt
  1. Craig Electronics CMP773 Front and Rear Camera Replacement, Front and Rear Camera: stap 1, afbeelding 1 van 2 Craig Electronics CMP773 Front and Rear Camera Replacement, Front and Rear Camera: stap 1, afbeelding 2 van 2
    • Remove the two Phillips #00 screws from the bottom of the screen.
  2. Craig Electronics CMP773 Front and Rear Camera Replacement: stap 2, afbeelding 1 van 2 Craig Electronics CMP773 Front and Rear Camera Replacement: stap 2, afbeelding 2 van 2
    • Insert a plastic opening tool underneath the screen.
    • Once the first tool is inserted, insert another opening tool along the same side of the tablet.
    • Pry them in opposite directions until the casing pops.
  3. Craig Electronics CMP773 Front and Rear Camera Replacement: stap 3, afbeelding 1 van 2 Craig Electronics CMP773 Front and Rear Camera Replacement: stap 3, afbeelding 2 van 2
    • Move the opening tool along the edge of the tablet to continue popping the casing loose.
    • Once the casing is about half loose, remove it by hand.
  4. Craig Electronics CMP773 Front and Rear Camera Replacement: stap 4, afbeelding 1 van 2 Craig Electronics CMP773 Front and Rear Camera Replacement: stap 4, afbeelding 2 van 2
    • Remove the tape from the power connection for the camera unit.
    • Unhinge the clamp on the camera power connection to expose the removable plug.
  5. Craig Electronics CMP773 Front and Rear Camera Replacement: stap 5, afbeelding 1 van 1
    • Gently remove the power ribbon from the connector.
  6. Craig Electronics CMP773 Front and Rear Camera Replacement: stap 6, afbeelding 1 van 2 Craig Electronics CMP773 Front and Rear Camera Replacement: stap 6, afbeelding 2 van 2
    • Use the spudger to dislodge camera unit from the casing and remove it from the device.
Conclusie
Luke VanLangevelde
133 Reputatie
1 Handleiding geschreven
IUPUI, Team S3-G4, Harley Fall 2019 Lid van IUPUI, Team S3-G4, Harley Fall 2019
IUPUI-HARLEY-F19S3G4
4 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 88
