Ga door naar hoofdinhoud
Craig CMP801 LCD Screen Replacement
Wat je nodig hebt
  1. Craig CMP801 LCD Screen Replacement, Back Cover: stap 1, afbeelding 1 van 2 Craig CMP801 LCD Screen Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 LCD Screen Replacement: stap 2, afbeelding 1 van 2 Craig CMP801 LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 LCD Screen Replacement: stap 3, afbeelding 1 van 2 Craig CMP801 LCD Screen Replacement: stap 3, afbeelding 2 van 2
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 LCD Screen Replacement, Volume Controls: stap 4, afbeelding 1 van 2 Craig CMP801 LCD Screen Replacement, Volume Controls: stap 4, afbeelding 2 van 2
    • After taking out the back cover, locate the black flap.
    • Open the black flap with the plastic opening tools.
    • Be careful not to break the flap when you open it.
  5. Craig CMP801 LCD Screen Replacement: stap 5, afbeelding 1 van 2 Craig CMP801 LCD Screen Replacement: stap 5, afbeelding 2 van 2
    • Once the tab is released, use the angled tweezers to take out the tab.
    • Be careful not to scratch the tab.
  6. Craig CMP801 LCD Screen Replacement: stap 6, afbeelding 1 van 2 Craig CMP801 LCD Screen Replacement: stap 6, afbeelding 2 van 2
    • Use the angled tweezers to pull the volume controls out and replace it with a new one.
  7. Craig CMP801 LCD Screen Replacement, Battery: stap 7, afbeelding 1 van 3 Craig CMP801 LCD Screen Replacement, Battery: stap 7, afbeelding 2 van 3 Craig CMP801 LCD Screen Replacement, Battery: stap 7, afbeelding 3 van 3
    • Locate the white plug next to the battery.
    • Use your fingers to pull off white plug that connected to the battery.
    • Be careful not to pull or break the wires on the bottom.
  8. Craig CMP801 LCD Screen Replacement: stap 8, afbeelding 1 van 3 Craig CMP801 LCD Screen Replacement: stap 8, afbeelding 2 van 3 Craig CMP801 LCD Screen Replacement: stap 8, afbeelding 3 van 3
    • The battery should only be connected to the LCD by adhesive tape.
    • Using force, carefully remove the battery while holding the LCD in place.
  9. Craig CMP801 LCD Screen Replacement, LCD Screen: stap 9, afbeelding 1 van 3 Craig CMP801 LCD Screen Replacement, LCD Screen: stap 9, afbeelding 2 van 3 Craig CMP801 LCD Screen Replacement, LCD Screen: stap 9, afbeelding 3 van 3
    • Open the three black flaps located on each side of the motherboard.
  10. Craig CMP801 LCD Screen Replacement: stap 10, afbeelding 1 van 2 Craig CMP801 LCD Screen Replacement: stap 10, afbeelding 2 van 2
    • Then detach each of the three tabs from the LCD screen.
  11. Craig CMP801 LCD Screen Replacement: stap 11, afbeelding 1 van 2 Craig CMP801 LCD Screen Replacement: stap 11, afbeelding 2 van 2
    • Using a Philips 0 Screwdriver, remove the screws connecting the speaker to the motherboard.
    • Remove black plastic speaker holder.
  12. Craig CMP801 LCD Screen Replacement: stap 12, afbeelding 1 van 1
    • Remove the gray tape connecting the motherboard to the metal slate.
    • Use a spudger to separate the metal slate from the front touch screen.
  13. Craig CMP801 LCD Screen Replacement: stap 13, afbeelding 1 van 2 Craig CMP801 LCD Screen Replacement: stap 13, afbeelding 2 van 2
    • Carefully slide out the metal slate and LCD screen from underneath the motherboard.
  14. Craig CMP801 LCD Screen Replacement: stap 14, afbeelding 1 van 1
    • Flip over the metal slate and separate the LCD screen from it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Anh
304 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 1,087
