Ga door naar hoofdinhoud
Craig CMP801 Front and Rear Facing Camera Replacement
Wat je nodig hebt
  1. Craig CMP801 Front and Rear Facing Camera Replacement, Back Cover: stap 1, afbeelding 1 van 2 Craig CMP801 Front and Rear Facing Camera Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 Front and Rear Facing Camera Replacement: stap 2, afbeelding 1 van 2 Craig CMP801 Front and Rear Facing Camera Replacement: stap 2, afbeelding 2 van 2
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 Front and Rear Facing Camera Replacement: stap 3, afbeelding 1 van 2 Craig CMP801 Front and Rear Facing Camera Replacement: stap 3, afbeelding 2 van 2
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 Front and Rear Facing Camera Replacement, Front and Rear Facing Camera: stap 4, afbeelding 1 van 2 Craig CMP801 Front and Rear Facing Camera Replacement, Front and Rear Facing Camera: stap 4, afbeelding 2 van 2
    • Once the back cover is removed, gently remove the black tape that covers the front and rear facing camera.
  5. Craig CMP801 Front and Rear Facing Camera Replacement: stap 5, afbeelding 1 van 1
    • Near the edge of the device, lift up the tab connected to the front-facing camera.
  6. Craig CMP801 Front and Rear Facing Camera Replacement: stap 6, afbeelding 1 van 2 Craig CMP801 Front and Rear Facing Camera Replacement: stap 6, afbeelding 2 van 2
    • Locate the black flap that covers and holds down the tab connected to the rear-facing camera.
    • Flip the flap up to release the tab.
  7. Craig CMP801 Front and Rear Facing Camera Replacement: stap 7, afbeelding 1 van 2 Craig CMP801 Front and Rear Facing Camera Replacement: stap 7, afbeelding 2 van 2
    • Gently pull on the tab connected to the front-facing camera to release both the front and rear-facing cameras.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Erin
117 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 235
