Ga door naar hoofdinhoud
Craig CMP801 Battery Replacement
Wat je nodig hebt
  1. Craig CMP801 Battery Replacement, Back Cover: stap 1, afbeelding 1 van 2 Craig CMP801 Battery Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 Battery Replacement: stap 2, afbeelding 1 van 2 Craig CMP801 Battery Replacement: stap 2, afbeelding 2 van 2
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 Battery Replacement: stap 3, afbeelding 1 van 2 Craig CMP801 Battery Replacement: stap 3, afbeelding 2 van 2
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 Battery Replacement, Battery: stap 4, afbeelding 1 van 3 Craig CMP801 Battery Replacement, Battery: stap 4, afbeelding 2 van 3 Craig CMP801 Battery Replacement, Battery: stap 4, afbeelding 3 van 3
    • Locate the white plug next to the battery.
    • Use your fingers to pull off white plug that connected to the battery.
    • Be careful not to pull or break the wires on the bottom.
  5. Craig CMP801 Battery Replacement: stap 5, afbeelding 1 van 3 Craig CMP801 Battery Replacement: stap 5, afbeelding 2 van 3 Craig CMP801 Battery Replacement: stap 5, afbeelding 3 van 3
    • The battery should only be connected to the LCD by adhesive tape.
    • Using force, carefully remove the battery while holding the LCD in place.
Conclusie
Duyen
308 Reputatie
2 handleidingen geschreven
1Gids Commentaar
Where do I find a battery cmp749 ???
kourriclay929 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 25
Altijd: 1,324
