Ga door naar hoofdinhoud
Craftsman Model 315.10721 Table Guard Replacement
Wat je nodig hebt
  1. Craftsman Model 315.10721 Table Guard Replacement, Table Guard: stap 1, afbeelding 1 van 1
    • Using a flathead screwdriver, remove the 1/2" flathead screw to allow the table guard to pivot.
  2. Craftsman Model 315.10721 Table Guard Replacement: stap 2, afbeelding 1 van 1
    • Pivot the table guard from its upright position to an angle.
    • Using a Phillips #1 screwdriver, remove the 1" Phillips screw and the nut on the opposite side.
  3. Craftsman Model 315.10721 Table Guard Replacement: stap 3, afbeelding 1 van 1
    • Using the Phillips #1 screwdriver, remove eight 1" Philips screws from the main case.
    • Carefully remove the main case to expose the inside of the saw.
  4. Craftsman Model 315.10721 Table Guard Replacement: stap 4, afbeelding 1 van 1
    • Remove the old table guard by gently lifting it away from the main case.
    • Replace the old table guard with the new one by placing it in the same orientation as the one removed.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Riley Hilliker
557 Reputatie
5 handleidingen geschreven
Cal Poly, Team 4-47, Amido Fall 2014 Lid van Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 Leden
2 opmerkingen
Where can I get a replacement table guard???
Roger Coyle - Antwoord
Where can I get a replacement table guard for this jig saw????????
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 631
