Ga door naar hoofdinhoud
Craftsman Model 315.10721 Blade Replacement
Wat je nodig hebt
  1. Craftsman Model 315.10721 Blade Replacement, Blade: stap 1, afbeelding 1 van 1
    • Be sure to unplug the saw before proceeding.
    • Using a flathead screwdriver, loosen the first 7/32" flathead screw on the saw blade clamp.
    • Rotate the saw blade clamp 90 degrees to the left and loosen the second 7/32" flathead screw
    • It is not necessary to completely remove the screws.
  2. Craftsman Model 315.10721 Blade Replacement: stap 2, afbeelding 1 van 1
    • Carefully take the replacement blade and insert it into the saw blade clamp.
    • To secure the blade, retighten both 7/32" flathead screws on the saw blade clamp.
Eindstreep
Riley Hilliker
557 Reputatie
5 handleidingen geschreven
Cal Poly, Team 4-47, Amido Fall 2014 Lid van Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 Leden
2 opmerkingen
Where can I get replacement blades for this saw.
Edward - Antwoord
Where can I get replacement blades for this saw?
Edward - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 59
Altijd: 3,367
