Inleiding
Replacing the blade on your Craftsman Model 315.10721 is fairly straightforward. However, replacing the blade can be dangerous, so please take caution when handling the blade and ensure that your saw is unplugged before beginning repair.
Wat je nodig hebt
Using a flathead screwdriver, loosen the first 7/32" flathead screw on the saw blade clamp.
Rotate the saw blade clamp 90 degrees to the left and loosen the second 7/32" flathead screw
Bijna klaar!
Eindstreep
