Ga door naar hoofdinhoud
Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank Replacement
Wat je nodig hebt
  1. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement, Fuel Tank: stap 1, afbeelding 1 van 2 Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement, Fuel Tank: stap 1, afbeelding 2 van 2
    • Remove the fuel line from the fuel tank with pliers.
  2. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: stap 2, afbeelding 1 van 2 Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: stap 2, afbeelding 2 van 2
    • Take off the fuel cap and place a safe container under the fuel line.
    • Make sure to drain all of the fuel from the fuel tank into the container.
  3. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: stap 3, afbeelding 1 van 2 Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: stap 3, afbeelding 2 van 2
    • Remove the four support bolts on the top of the tank and motor with a crescent wrench or socket wrench.
  4. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: stap 4, afbeelding 1 van 1
    • Lift the fuel tank off of the lower supporting brackets.
  5. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: stap 5, afbeelding 1 van 1
    • Replace the cracked fuel tank and place the new one onto the lower supporting brackets.
  6. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: stap 6, afbeelding 1 van 1
    • Screw in the top four supporting bracket bolts with a crescent wrench or socket wrench to hold the new fuel tank in place.
  7. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: stap 7, afbeelding 1 van 1
    • Reconnect the fuel line and hose clamp.
  8. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: stap 8, afbeelding 1 van 1
    • Fill the tank with fuel.
    • Check to make sure that the hose clamp is not leaking.
Conclusie
Megan Smith
169 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 2,013
