Inleiding
Before starting, please:
- make sure nothing is attached (such as AC adapter, USB, VGA, audio jack).
- remove any inserted SD card.
Wat je nodig hebt
Slide the switch on the bottom of the laptop until the battery pops out.
Once the battery pops out, you can remove it.
Using a pair of tweezers, remove the two rear rubber feet to expose two hidden screws.
Remove ten 3 mm screws in the battery compartment using a Phillips #00 screwdriver.
Remove two 4.5 mm screws under the rubber feet using a Phillips #00 screwdriver.
Find the SSD located on a corner of the side directly opposite where the laptop screen and device body are connected.
Remove one black screw on the SSD using a PH #00 screwdriver.
Size ph#00, approximately 3 mm long.
5 andere personen hebben deze handleiding voltooid.
