Ga door naar hoofdinhoud
Cr-48 Chromebook SSD Replacement
Wat je nodig hebt
  1. Cr-48 Chromebook SSD Replacement, Battery: stap 1, afbeelding 1 van 3 Cr-48 Chromebook SSD Replacement, Battery: stap 1, afbeelding 2 van 3 Cr-48 Chromebook SSD Replacement, Battery: stap 1, afbeelding 3 van 3
    • Slide the switch on the bottom of the laptop until the battery pops out.
    • Once the battery pops out, you can remove it.
  2. Cr-48 Chromebook SSD Replacement, Remove Rear Rubber Feet: stap 2, afbeelding 1 van 2 Cr-48 Chromebook SSD Replacement, Remove Rear Rubber Feet: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using a pair of tweezers, remove the two rear rubber feet to expose two hidden screws.
  3. Cr-48 Chromebook SSD Replacement, Remove Screws: stap 3, afbeelding 1 van 3 Cr-48 Chromebook SSD Replacement, Remove Screws: stap 3, afbeelding 2 van 3 Cr-48 Chromebook SSD Replacement, Remove Screws: stap 3, afbeelding 3 van 3
    • Remove ten 3 mm screws in the battery compartment using a Phillips #00 screwdriver.
    • Remove two 4.5 mm screws under the rubber feet using a Phillips #00 screwdriver.
  4. Cr-48 Chromebook SSD Replacement: stap 4, afbeelding 1 van 3 Cr-48 Chromebook SSD Replacement: stap 4, afbeelding 2 van 3 Cr-48 Chromebook SSD Replacement: stap 4, afbeelding 3 van 3
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
  5. Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: stap 5, afbeelding 1 van 3 Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: stap 5, afbeelding 2 van 3 Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: stap 5, afbeelding 3 van 3
    • Find the SSD located on a corner of the side directly opposite where the laptop screen and device body are connected.
    • Remove one black screw on the SSD using a PH #00 screwdriver.
    • Size ph#00, approximately 3 mm long.
    • Once unscrewed, the SSD will pop up from the device.
  6. Cr-48 Chromebook SSD Replacement, Remove SSD: stap 6, afbeelding 1 van 2 Cr-48 Chromebook SSD Replacement, Remove SSD: stap 6, afbeelding 2 van 2
    • Firmly grasp the SSD with two fingers slightly upwards and pull.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Athar
365 Reputatie
2 handleidingen geschreven
CSU Fullerton, Team 2-2, Bruce Fall 2014 Lid van CSU Fullerton, Team 2-2, Bruce Fall 2014
CSUF-BRUCE-F14S2G2
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 53
Altijd: 3,253
