Ga door naar hoofdinhoud
Cowin E7 Ear Cushion Replacement
Wat je nodig hebt
  1. Cowin E7 Ear Cushion Replacement, Ear Cushion: stap 1, afbeelding 1 van 1
    • Inspect the seal around the edge of each ear cushion for damage or instability.
    • Make note of which ear cushion needs to be replaced.
  2. Cowin E7 Ear Cushion Replacement: stap 2, afbeelding 1 van 1
    • Firmly grasp the ear cushion on one side and pull up.
    • The ear cushion is only attached by a few spots of glue, so it should not take much force to remove.
  3. Cowin E7 Ear Cushion Replacement: stap 3, afbeelding 1 van 1
    • Spread multipurpose glue around the edge of the seal.
    • Keep in mind that the more glue you use, the harder it will be to remove the ear cushions again.
    • Place the replacement ear cushions where the damaged cushions were.
    • Hold for at least thirty seconds to ensure the glue has time to dry and seal the new cushions to the headphones.
Eindstreep
4 andere personen hebben deze handleiding voltooid.
Jacob Burrer
439 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-2, Mellen Spring 2022 Lid van UMass Dartmouth, Team 2-2, Mellen Spring 2022
UMASSD-MELLEN-S22S2G2
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 45
Afgelopen 30 dagen: 203
Altijd: 4,830
