Ga door naar hoofdinhoud
Corsair Katar Scroll Wheel Replacement
Wat je nodig hebt
  1. Corsair Katar Scroll Wheel Replacement, Corsair Katar Disassembly: stap 1, afbeelding 1 van 2 Corsair Katar Scroll Wheel Replacement, Corsair Katar Disassembly: stap 1, afbeelding 2 van 2
    • Unplug your mouse before starting.
    • Flip the mouse over so the bottom is facing up.
  2. Corsair Katar Scroll Wheel Replacement: stap 2, afbeelding 1 van 1
    • Remove the three skates on the bottom of the mouse using the plastic opening tools.
    • Skates will be very sticky.
  3. Corsair Katar Scroll Wheel Replacement: stap 3, afbeelding 1 van 2 Corsair Katar Scroll Wheel Replacement: stap 3, afbeelding 2 van 2
    • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
  4. Corsair Katar Scroll Wheel Replacement: stap 4, afbeelding 1 van 1
    • Detach the bottom of the mouse from the upper shell.
    • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
    • Use the plastic opening tool to detach the white DPI sensor cable from its port.
    • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
  5. Corsair Katar Scroll Wheel Replacement, Scroll Wheel: stap 5, afbeelding 1 van 2 Corsair Katar Scroll Wheel Replacement, Scroll Wheel: stap 5, afbeelding 2 van 2
    • Use the JIS 0 screwdriver to remove the two 5mm screws on the motherboard.
  6. Corsair Katar Scroll Wheel Replacement: stap 6, afbeelding 1 van 1
    • Use the plastic opening tool to pry the white cable jack away from the motherboard.
    • Lift the motherboard away from the bottom of the mouse.
  7. Corsair Katar Scroll Wheel Replacement: stap 7, afbeelding 1 van 1
    • Push the scroll wheel to the right side of the motherboard as shown, then pull it away from the board to remove.
Conclusie
Margaret Loughren
594 Reputatie
5 handleidingen geschreven
UW Tacoma, Team S1-G3, Cardinal Summer 2018 Lid van UW Tacoma, Team S1-G3, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G3
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 53
Altijd: 1,967
