Ga door naar hoofdinhoud
Corsair Dark Core RGB PRO SE Scroll Wheel Replacement
Wat je nodig hebt
  1. Corsair Dark Core RGB PRO SE Scroll Wheel Replacement, Scroll Wheel: stap 1, afbeelding 1 van 1
    • Remove the front of the mouse, then put that part aside.
  2. Corsair Dark Core RGB PRO SE Scroll Wheel Replacement: stap 2, afbeelding 1 van 2 Corsair Dark Core RGB PRO SE Scroll Wheel Replacement: stap 2, afbeelding 2 van 2
    • To remove the left and right click buttons, pinch the latches together and carefully remove them.
    • Remove the two screws with a Phillips #00 screwdriver.
  3. Corsair Dark Core RGB PRO SE Scroll Wheel Replacement, Remove the adhesive: stap 3, afbeelding 1 van 1
    • Flip the mouse over and remove the adhesive carefully.
    • Remove the two screws using a Torx T5 screwdriver.
  4. Corsair Dark Core RGB PRO SE Scroll Wheel Replacement, Take off the top: stap 4, afbeelding 1 van 1
    • Carefully remove the top and put it aside.
  5. Corsair Dark Core RGB PRO SE Scroll Wheel Replacement: stap 5, afbeelding 1 van 1
    • Remove the four screws with a Phillips #00 screwdriver.
  6. Corsair Dark Core RGB PRO SE Scroll Wheel Replacement, Remove the slip tabs: stap 6, afbeelding 1 van 1
    • Remove the two black tabs by lifting them carefully. Then remove the white slip.
    • Carefully remove the green slip by moving the tabs and holding the slip outwards.
  7. Corsair Dark Core RGB PRO SE Scroll Wheel Replacement, Remove the battery: stap 7, afbeelding 1 van 1
    • Remove the battery.
    • This is optional, but might make the process easier.
  8. Corsair Dark Core RGB PRO SE Scroll Wheel Replacement, Take the first side button off: stap 8, afbeelding 1 van 1
    • Remove the screw and the first side button.
    • Right underneath the first side button, there is another screw connected to the second side button. Remove this screw as well.
  9. Corsair Dark Core RGB PRO SE Scroll Wheel Replacement, Detach the wheel tab: stap 9, afbeelding 1 van 1
    • Remove all 3 screws around the scroll wheel to detach the tab holding the wheel.
  10. Corsair Dark Core RGB PRO SE Scroll Wheel Replacement: stap 10, afbeelding 1 van 3 Corsair Dark Core RGB PRO SE Scroll Wheel Replacement: stap 10, afbeelding 2 van 3 Corsair Dark Core RGB PRO SE Scroll Wheel Replacement: stap 10, afbeelding 3 van 3
    • Remove the scroll wheel from the mouse.
    • Put the mouse aside and remove the black tab on the side of the scroll wheel.
    • Replace the scroll wheel.
Conclusie
To reassemble your device, follow these instructions in the reverse order.
Kelly ventura
181 Reputatie
1 Handleiding geschreven
Één opmerking
I have a reassembly tip and two bits of constructive (hopefully) criticism.
First the criticism, the article could use some suggestions on how to find a replacement scroll wheel to install (I was only looking to tear it down to clean the contacts as best I could, so it wasn't an issue for me). Also, the photo in step nine could use some adjustment, the top red circle is over two screws, and (at least it wasn't to me) it's not immediately obvious which is the correct one.
When reversing from steps 10 to 9 on reassembly, I found the magnets that keep the replaceable side piece in place kept either stopping the part going in correctly or pinging together (and across the room), I found that putting the side piece on kept the magnets in place and made putting the part back on much easier.
Paul - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 19
Afgelopen 7 dagen: 96
Afgelopen 30 dagen: 384
Altijd: 2,649
