Ga door naar hoofdinhoud
Coolpad Defiant Rear Camera Replacement
Wat je nodig hebt
  1. Coolpad Defiant Rear Camera Replacement, Back Cover: stap 1, afbeelding 1 van 2 Coolpad Defiant Rear Camera Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Rear Camera Replacement: stap 2, afbeelding 1 van 1
    • Remove the back cover from your device.
  3. Coolpad Defiant Rear Camera Replacement, Battery: stap 3, afbeelding 1 van 1
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
  4. Coolpad Defiant Rear Camera Replacement, Rear Camera: stap 4, afbeelding 1 van 1
    • Using a Phillips #000 screwdriver, remove the screws holding the rear mid-frame cover to the mid-frame assembly.
  5. Coolpad Defiant Rear Camera Replacement: stap 5, afbeelding 1 van 2 Coolpad Defiant Rear Camera Replacement: stap 5, afbeelding 2 van 2
    • Using either a plastic pry tool or your hands, pry the plastic cover away.
  6. Coolpad Defiant Rear Camera Replacement: stap 6, afbeelding 1 van 1
    • Using the Phillips #000 screwdriver, remove the three screws holding the top logic board to the main frame.
  7. Coolpad Defiant Rear Camera Replacement: stap 7, afbeelding 1 van 3 Coolpad Defiant Rear Camera Replacement: stap 7, afbeelding 2 van 3 Coolpad Defiant Rear Camera Replacement: stap 7, afbeelding 3 van 3
    • Using the plastic pry tool, remove the flex cables for the screen, side buttons, and digitizer.
    • Using the same tool, remove the antenna from the bottom logic board
  8. Coolpad Defiant Rear Camera Replacement: stap 8, afbeelding 1 van 3 Coolpad Defiant Rear Camera Replacement: stap 8, afbeelding 2 van 3 Coolpad Defiant Rear Camera Replacement: stap 8, afbeelding 3 van 3
    • Carefully pull up on the upper logic board starting from the top and pull it straight up.
    • Once the logic board is lifted perpendicular to the mid-frame, remove the flex cable on the bottom left side of the board.
  9. Coolpad Defiant Rear Camera Replacement: stap 9, afbeelding 1 van 1
    • Flipping the logic board upside down, use the plastic pry tool to disconnect the flex cable connecting the camera to the logic board.
    • Pull straight up on the camera and it will slide out of the logic board.
Conclusie
Johnny Boland
500 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 257
