Ga door naar hoofdinhoud
Coolpad Defiant Daughterboard Replacement
Wat je nodig hebt
  1. Coolpad Defiant Daughterboard Replacement, Back Cover: stap 1, afbeelding 1 van 2 Coolpad Defiant Daughterboard Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Daughterboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the back cover from your device.
  3. Coolpad Defiant Daughterboard Replacement, Battery: stap 3, afbeelding 1 van 1
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
  4. Coolpad Defiant Daughterboard Replacement, Daughterboard: stap 4, afbeelding 1 van 2 Coolpad Defiant Daughterboard Replacement, Daughterboard: stap 4, afbeelding 2 van 2
    • Remove all fifteen screws using the Phillips #000 screwdriver.
    • Remove the back panel after all screws are removed.
  5. Coolpad Defiant Daughterboard Replacement: stap 5, afbeelding 1 van 3 Coolpad Defiant Daughterboard Replacement: stap 5, afbeelding 2 van 3 Coolpad Defiant Daughterboard Replacement: stap 5, afbeelding 3 van 3
    • Disconnect the metal cable using the plastic spudger.
    • The remove the glued down speaker from the backing.
    • Disconnect the little black wire from lower logic board.
  6. Coolpad Defiant Daughterboard Replacement: stap 6, afbeelding 1 van 1
    • Using the plastic spudger remove the lower logic board because the only thing that is holding it down is glue.
Conclusie
Elijah Gastin
100 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 450
