Ga door naar hoofdinhoud
Coolpad Defiant Battery Replacement
Wat je nodig hebt
  1. Coolpad Defiant Battery Replacement, Back Cover: stap 1, afbeelding 1 van 2 Coolpad Defiant Battery Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the back cover from your device.
  3. Coolpad Defiant Battery Replacement, Battery: stap 3, afbeelding 1 van 1
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Johnny Boland
500 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 25
Altijd: 1,510
