Ga door naar hoofdinhoud
Cooler Master Laptop Fan Replacement
Wat je nodig hebt
  1. Cooler Master Laptop Fan Replacement, Fan: stap 1, afbeelding 1 van 1
    • Set your laptop cooler on the table and make sure it is not plugged into a laptop or powered on.
    • Never try to open the cooler while plugged in.
  2. Cooler Master Laptop Fan Replacement: stap 2, afbeelding 1 van 1
    • Flip the Device over and find ten folded metal slots holding the metal cover onto the base.
  3. Cooler Master Laptop Fan Replacement: stap 3, afbeelding 1 van 3 Cooler Master Laptop Fan Replacement: stap 3, afbeelding 2 van 3 Cooler Master Laptop Fan Replacement: stap 3, afbeelding 3 van 3
    • Bend each metal flap straight up with the pliers to allow the metal cover to slide off.
  4. Cooler Master Laptop Fan Replacement: stap 4, afbeelding 1 van 2 Cooler Master Laptop Fan Replacement: stap 4, afbeelding 2 van 2
    • Remove the cover and expose the inside of the Cooler.
  5. Cooler Master Laptop Fan Replacement: stap 5, afbeelding 1 van 2 Cooler Master Laptop Fan Replacement: stap 5, afbeelding 2 van 2
    • Unplug the power cable to the fan.
    • Make sure not to apply too much force and disconnect the wires to the device.
  6. Cooler Master Laptop Fan Replacement: stap 6, afbeelding 1 van 2 Cooler Master Laptop Fan Replacement: stap 6, afbeelding 2 van 2
    • On the bottom of the base locate the screw holes under the sticker on the base.
    • Unscrew the three fan screws.
  7. Cooler Master Laptop Fan Replacement: stap 7, afbeelding 1 van 1
    • Once all the pieces are taken apart, set aside the old fan and prep the new one for installation.
  8. Cooler Master Laptop Fan Replacement: stap 8, afbeelding 1 van 1
    • Apply a small amount of thermal compound to the base where the fan sets.
    • Make sure to apply thermal compound to keep the fan from overheating and damaging the base.
  9. Cooler Master Laptop Fan Replacement: stap 9, afbeelding 1 van 2 Cooler Master Laptop Fan Replacement: stap 9, afbeelding 2 van 2
    • Connect power cable for the fan and place the cables back in their slots.
  10. Cooler Master Laptop Fan Replacement: stap 10, afbeelding 1 van 2 Cooler Master Laptop Fan Replacement: stap 10, afbeelding 2 van 2
    • Screw fan back onto base.
  11. Cooler Master Laptop Fan Replacement: stap 11, afbeelding 1 van 1
    • Place cover back on base.
  12. Cooler Master Laptop Fan Replacement: stap 12, afbeelding 1 van 1
    • Fold all metal flaps back to hold cover on base.
  13. Cooler Master Laptop Fan Replacement: stap 13, afbeelding 1 van 1
    • Flip it over and it's finished.
Conclusie
Plug in the USB to insure proper working condition. And the cooling pad fan replacement is done.
2 opmerkingen
Hi there,
I’ve got a Targus Lap Chill Matt (Laptop Cooling Pad 15 - 17" Laptops) but the USB port had worn out and require a new replacement. Does anyone have any examples on how to replace the UBS port from a Laptop Cooler Pad?
Thanks!
rolly - Antwoord
Hi,
Just wanted to say huge thanks to you for this guideline! I have a Cooler Master Notepal L1 and the fan kept making noises. But now it works totally fine after I was able to open the cover.
Thanks again!
//Parisa
Parisa - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 90
Altijd: 5,518
