Ga door naar hoofdinhoud
Convert a 360 (Fat) hard drive into a 360 S hard drive
Wat je nodig hebt
  1. Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: stap 1, afbeelding 1 van 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: stap 1, afbeelding 2 van 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: stap 1, afbeelding 3 van 3
    • Buy the drive at a cost you can afford to eat. This will void any warranties offered.
    • Remove the 3 screws from the bottom of the drive. Use a T6 Torx driver.
    • Remove the warranty seal and final screw. Use a T6 Torx driver.
  2. Convert a 360 (Fat) hard drive into a 360 S hard drive, Disassembly tip: stap 2, afbeelding 1 van 1
    • If the drive is difficult to open and you are opening it to put the drive into a later Xbox 360 with no intention to preserve the enclosure, a screwdriver or pry tool can help.
    • If you are opening it to replace the drive inside for an original console, it is best to use a plastic pry tool instead. While a screwdriver "works" it will likely mar the enclosure.
  3. Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: stap 3, afbeelding 1 van 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: stap 3, afbeelding 2 van 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: stap 3, afbeelding 3 van 3
    • If you are taking the enclosure apart for the bare drive, less caution is needed.
    • After removing the 4 bottom screws, remove the top cover. Remove the spring and locking tab before removing the drive cage.
    • Remove the drive cage from the drive enclosure. If the drive has never been opened, additonal force may be required.
  4. Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: stap 4, afbeelding 1 van 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: stap 4, afbeelding 2 van 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: stap 4, afbeelding 3 van 3
    • Remove the four T10 Torx screws securing the hard drive.
    • After removing the screws, slide the top cover off and disconnect the drive.
    • Disconnect the hard drive and remove it from the enclosure.
  5. Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: stap 5, afbeelding 1 van 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: stap 5, afbeelding 2 van 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: stap 5, afbeelding 3 van 3
    • If you do not use an official hard drive, you will need a WD hard drive, the Xbox hard drive sector security file and HDDhackr to partition the drive. Partition 2 must be restored manually.
    • After removing the drive from the old enclosure, open the new enclosure.
    • Put the drive in the enclosure label side up. Space may need to be added for 7mm drives.
    • Close the enclosure and install it in your console.
Eindstreep
Nick
89.825 Reputatie
52 handleidingen geschreven
Master Techs Lid van Master Techs
Community
321 Leden
1.516 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 45
Altijd: 3,594
