Ga door naar hoofdinhoud
Controller Plate/Buttons Replacement
Wat je nodig hebt
  1. Controller Plate/Buttons Replacement, Controller Plate/Buttons Replacement: stap 1, afbeelding 1 van 1
    • Follow the Prerequisite Guide on how to Replace the Battery to prepare the phone for disassemble. Remove, but do not replace the battery.
    Vraag FixBot
    Voeg opmerking toe
  2. Controller Plate/Buttons Replacement: stap 2, afbeelding 1 van 1
    • Remove all screws on the plastic case with a T6 Torx T-4 screwdriver, as shown.
    • Blue Circle: T6 Torx, Length 5mm
    • Red Circle: T6 Torx, Length 4mm
    • The screen and other parts are now loose and can easily fall off.
    Vraag FixBot
    Voeg opmerking toe
  3. Controller Plate/Buttons Replacement: stap 3, afbeelding 1 van 1
    • Separate the back cover from the phone. A plastic removal tool can be used here.
    Vraag FixBot
    Voeg opmerking toe
  4. Controller Plate/Buttons Replacement: stap 4, afbeelding 1 van 1
    • Remove the last two screws holding the motherboard to the device.
    • Orange Circle: 00 Philips head, Length 2 mm
    Vraag FixBot
    Voeg opmerking toe
  5. Controller Plate/Buttons Replacement: stap 5, afbeelding 1 van 1
    • Gently pull up the motherboard. Some force may need to be applied.
    • Some wires on the reverse side are still attached.
    • Make sure to line up the plastic connectors highlighted by the red circles when re-assembling.
    Vraag FixBot
    Voeg opmerking toe
  6. Controller Plate/Buttons Replacement: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Break the break the data cable connection between the motherboard and the controller plate by gently pulling out the connecting wire with tweezers.
    • When the device is orientated as shown in the picture, apply the force parallel to the motherboard and away from the device, as depicted by the red arrows.
    Vraag FixBot
    Voeg opmerking toe
  7. Controller Plate/Buttons Replacement: stap 7, afbeelding 1 van 1
    • The entire controller plate should now be free from the phone. All the buttons can now be taken off by gently pressing them out.
    • If the touch-pad joysticks do not work, the entire plate needs to be replaced.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Pieter Boersma
455 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 7-3, Cichon Spring 2015 Lid van UMass Dartmouth, Team 7-3, Cichon Spring 2015
UMASSD-CICHON-S15S7G3
3 Leden
9 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 60
Altijd: 1,852
