Ga door naar hoofdinhoud
Connect Four Electronic Handheld Speaker Replacement
Wat je nodig hebt
  1. Connect Four Electronic Handheld Speaker Replacement, Ensure the device is off.: stap 1, afbeelding 1 van 1
    • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
  2. Connect Four Electronic Handheld Speaker Replacement, Removing the battery casing.: stap 2, afbeelding 1 van 2 Connect Four Electronic Handheld Speaker Replacement, Removing the battery casing.: stap 2, afbeelding 2 van 2
    • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
    • Slide the cover off and remove the battery.
  3. Connect Four Electronic Handheld Speaker Replacement, Removing/Replacing the Back Casing: stap 3, afbeelding 1 van 2 Connect Four Electronic Handheld Speaker Replacement, Removing/Replacing the Back Casing: stap 3, afbeelding 2 van 2
    • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
    • Carefully remove the back casing.
    • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
  4. Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: stap 4, afbeelding 1 van 3 Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: stap 4, afbeelding 2 van 3 Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: stap 4, afbeelding 3 van 3
    • If the speaker is in working condition, but the wires are broken or disconnected, skip this step and move on to step 5.
    • Locate the speaker on the back casing.
    • Using a spudger, wedge the speaker out of its place until it slides out.
    • Take the replacement speaker and wedge it back into its space.
  5. Connect Four Electronic Handheld Speaker Replacement, Re-Soldering the Speaker Wire: stap 5, afbeelding 1 van 1
    • Using a soldering iron, solder both red wires to their appropriate connections.
    • Be extremely careful when using a soldering iron! Contact with the tip could cause severe burns.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Wil
313 Reputatie
3 handleidingen geschreven
Baylor, Team 8-11, Williams Fall 2014 Lid van Baylor, Team 8-11, Williams Fall 2014
BU-WILLIAMS-F14S8G11
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 244
