Ga door naar hoofdinhoud
Connect Four Electronic Handheld Battery Compartment Replacement
Wat je nodig hebt
  1. Connect Four Electronic Handheld Battery Compartment Replacement, Ensure the device is off.: stap 1, afbeelding 1 van 1
    • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
  2. Connect Four Electronic Handheld Battery Compartment Replacement, Removing the battery casing.: stap 2, afbeelding 1 van 2 Connect Four Electronic Handheld Battery Compartment Replacement, Removing the battery casing.: stap 2, afbeelding 2 van 2
    • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
    • Slide the cover off and remove the battery.
Conclusie
Kamaryn
225 Reputatie
2 handleidingen geschreven
Baylor, Team 8-11, Williams Fall 2014 Lid van Baylor, Team 8-11, Williams Fall 2014
BU-WILLIAMS-F14S8G11
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 124
