Ga door naar hoofdinhoud
Conair True Glow Lighted Mirror LED Bulb Replacement
Wat je nodig hebt
  1. Conair True Glow Lighted Mirror LED Bulb Replacement, LED Bulb: stap 1, afbeelding 1 van 1
    • Unplug and remove batteries to make sure the ring light does not turn on while repairing.
  2. Conair True Glow Lighted Mirror LED Bulb Replacement: stap 2, afbeelding 1 van 3 Conair True Glow Lighted Mirror LED Bulb Replacement: stap 2, afbeelding 2 van 3 Conair True Glow Lighted Mirror LED Bulb Replacement: stap 2, afbeelding 3 van 3
    • Remove the two 2 mm screws on the side of the ring mirror (one on each side) using a Phillips #00 screwdriver.
  3. Conair True Glow Lighted Mirror LED Bulb Replacement: stap 3, afbeelding 1 van 1
    • Push the cover towards you and slide away from the rest of the mirror.
  4. Conair True Glow Lighted Mirror LED Bulb Replacement: stap 4, afbeelding 1 van 1
    • Using your hands, gently unscrew the old LED light bulb in a counter-clockwise direction.
  5. Conair True Glow Lighted Mirror LED Bulb Replacement: stap 5, afbeelding 1 van 1
    • Use your hands to screw in the new LED light bulb in a clockwise direction.
  6. Conair True Glow Lighted Mirror LED Bulb Replacement: stap 6, afbeelding 1 van 1
    • Take the cover and push it back down in place.
  7. Conair True Glow Lighted Mirror LED Bulb Replacement: stap 7, afbeelding 1 van 1
    • Screw in the two 2 mm screws on each side of the mirror using a Phillips #00 screwdriver.
  8. Conair True Glow Lighted Mirror LED Bulb Replacement: stap 8, afbeelding 1 van 1
    • Plug the mirror in and reinsert batteries to turn it on.
  9. Conair True Glow Lighted Mirror LED Bulb Replacement: stap 9, afbeelding 1 van 1
    • Enjoy your fixed LED ring mirror light!
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Dave Inthavong
216 Reputatie
1 Handleiding geschreven
Één opmerking
What to do to get over to release. I’ve taken the screws out but cannot get the cover to release.
Bonnie Smith - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 88
Altijd: 2,453
