Ga door naar hoofdinhoud
Conair Infiniti Pro Model 259NP Fan Grill Replacement
Wat je nodig hebt
  1. Conair Infiniti Pro Model 259NP Fan Grill Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
    • Hold the hair dryer by the handle so that the back panel faces up.
  2. Conair Infiniti Pro Model 259NP Fan Grill Replacement: stap 2, afbeelding 1 van 2 Conair Infiniti Pro Model 259NP Fan Grill Replacement: stap 2, afbeelding 2 van 2
    • Remove the two 15.875 mm Phillips #2 screws from the back panel.
  3. Conair Infiniti Pro Model 259NP Fan Grill Replacement: stap 3, afbeelding 1 van 3 Conair Infiniti Pro Model 259NP Fan Grill Replacement: stap 3, afbeelding 2 van 3 Conair Infiniti Pro Model 259NP Fan Grill Replacement: stap 3, afbeelding 3 van 3
    • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
    • Continue separating the back panel, working along the seam.
    • With moderate force, completely remove the back panel from the hair dryer.
  4. Conair Infiniti Pro Model 259NP Fan Grill Replacement, Fan Motor Assembly: stap 4, afbeelding 1 van 2 Conair Infiniti Pro Model 259NP Fan Grill Replacement, Fan Motor Assembly: stap 4, afbeelding 2 van 2
    • Hold the hair dryer by the nozzle so that the handle points to the left.
    • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
  5. Conair Infiniti Pro Model 259NP Fan Grill Replacement: stap 5, afbeelding 1 van 3 Conair Infiniti Pro Model 259NP Fan Grill Replacement: stap 5, afbeelding 2 van 3 Conair Infiniti Pro Model 259NP Fan Grill Replacement: stap 5, afbeelding 3 van 3
    • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
    • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
    • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
  6. Conair Infiniti Pro Model 259NP Fan Grill Replacement, Fan Grill: stap 6, afbeelding 1 van 1
    • Hold the front panel of the hair dryer by the nozzle facing upward.
  7. Conair Infiniti Pro Model 259NP Fan Grill Replacement: stap 7, afbeelding 1 van 2 Conair Infiniti Pro Model 259NP Fan Grill Replacement: stap 7, afbeelding 2 van 2
    • Using your index finger push the fan grill down with moderate force.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Timothy Lo
1.172 Reputatie
7 handleidingen geschreven
Cal Poly, Team 10-58, Amido Spring 2014 Lid van Cal Poly, Team 10-58, Amido Spring 2014
CPSU-AMIDO-S14S10G58
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 1,310
