Ga door naar hoofdinhoud
Compaq iPAQ Pocket PC 3830 Battery Replacement
Wat je nodig hebt
  1. Compaq iPAQ Pocket PC 3830 Battery Replacement, Remove four screws from back cover: stap 1, afbeelding 1 van 2 Compaq iPAQ Pocket PC 3830 Battery Replacement, Remove four screws from back cover: stap 1, afbeelding 2 van 2
    • Remove the four 0.8 mm Phillips #00 screws from the back cover.
  2. Compaq iPAQ Pocket PC 3830 Battery Replacement: stap 2, afbeelding 1 van 1
    • Detach the yellow wire from comb that is attached to the battery.
  3. Compaq iPAQ Pocket PC 3830 Battery Replacement: stap 3, afbeelding 1 van 1
    • The yellow wire is removed from the comb attached to the battery.
  4. Compaq iPAQ Pocket PC 3830 Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery using tweezers from back cover.
  5. Compaq iPAQ Pocket PC 3830 Battery Replacement: stap 5, afbeelding 1 van 1
    • Detach the battery from back cover.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Sedina Cavcic
464 Reputatie
3 handleidingen geschreven
2 opmerkingen
One question; Where can I get a new battery????
Every place I have looked have a smaller batter,  not like the one you show.
Stephen
oharasc85@gmail.com
Stephen O'Hara - Antwoord
we are in need of battery
Danionics DLP 305590
Quantity : 02 Nos.
Please send us the lowest estimate.
Mail ID: electronics@pmtpims.org
ELECTRONICS1 PIMS - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 23
Altijd: 3,128
