Inleiding
The WiFi card allows you to connect to wireless networks. Many issues are caused by incorrectly configured software or drivers. If you've already exhausted your software troubleshooting options, follow this guide to replace the WiFi card.
Wat je nodig hebt
Shutdown the computer.
Remove all external devices.
Unplug the power, and any other cords, from the laptop.
Turn the laptop upside down, with the front towards you.
Loosen the two 5mm Phillips #1 screws that secure the memory module compartment cover to the computer.
Lift the front edge of the memory module compartment cover and swing it back to remove it.
Loosen the 5mm Phillips #1 screw that secures the Mini PCI compartment cover to the computer.
Lift the rear edge of the Mini PCI compartment cover, and swing it forward to remove it.
