Ga door naar hoofdinhoud
Compaq Presario V2414NR RAM Replacement
Wat je nodig hebt
  1. Compaq Presario V2414NR RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Shutdown the computer.
    • Remove all external devices.
    • Unplug the power, and any other cords, from the laptop.
    • Turn the laptop upside down, with the front towards you.
  2. Compaq Presario V2414NR RAM Replacement: stap 2, afbeelding 1 van 2 Compaq Presario V2414NR RAM Replacement: stap 2, afbeelding 2 van 2
    • Slide the battery release latch to the left until the battery pops up.
    • Lift the front edge of the battery pack and swing it back to remove it.
    • When reassembling, first align the back of the battery with the chassis, then press the front downwards until it latches.
  3. Compaq Presario V2414NR RAM Replacement, RAM Cover: stap 3, afbeelding 1 van 2 Compaq Presario V2414NR RAM Replacement, RAM Cover: stap 3, afbeelding 2 van 2
    • Loosen the two 5mm Phillips #1 screws that secure the memory module compartment cover to the computer.
    • These screws are captured to the cover panel.
    • Lift the front edge of the memory module compartment cover and swing it back to remove it.
  4. Compaq Presario V2414NR RAM Replacement, RAM: stap 4, afbeelding 1 van 2 Compaq Presario V2414NR RAM Replacement, RAM: stap 4, afbeelding 2 van 2
    • Use your fingers, or plastic opening tools, to spread the metal retaining tabs on each side of the RAM outwards until the module pops up.
    • Pull the module out of the socket at the same angle it is now oriented.
    • Repeat these steps to remove the second memory module.
    • When reassembling, align the offset notch on the RAM contacts with the tab on the socket and insert at a 30 degree angle.
Conclusie
Rylie Schmidt
765 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team 2-1, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 2-1, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G1
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 240
