Wat je nodig hebt
Lift the keyboard in the middle with a spudger
Remove 4 clips by bending keyboard in middle, do not force the clips at the sides
Do not remove the keyboard fully, it is attached via a ribbon cable
Lift keyboard slightly
Push each side of ribbon cable connector
Fully remove keyboard
Remove 2x Phillips M2.5x8mm screws from under the display
Remove 4x Phillips M2x2.8mm screws from the battery compartment
Turn over the laptop
Use a spudger to lift the ribbon cable hinged clip
Pull the ribbon cable out of the connector
Disconnect the display cable
Disconnect the microphone connector
Pull out the microphone LED from it's clip
Unroute the cables from their holders
Pull the wifi antennas through from the back of the laptop
Unroute the antenna cables from their guides
Remove 4x Phillips #1 M2.5x8mm screws from display hinges
Carefully lift display out making sure no cables are snagged
Één andere persoon heeft deze handleiding voltooid.
