Ga door naar hoofdinhoud
Compaq Mini 110 Top Cover Replacement
Wat je nodig hebt
  1. Compaq Mini 110 Top Cover Replacement, Battery: stap 1, afbeelding 1 van 2 Compaq Mini 110 Top Cover Replacement, Battery: stap 1, afbeelding 2 van 2
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
    Vraag FixBot
  2. Compaq Mini 110 Top Cover Replacement: stap 2, afbeelding 1 van 3 Compaq Mini 110 Top Cover Replacement: stap 2, afbeelding 2 van 3 Compaq Mini 110 Top Cover Replacement: stap 2, afbeelding 3 van 3
    • Push both tabs inward simultaneously and slide the battery out.
    Vraag FixBot
  3. Compaq Mini 110 Top Cover Replacement, RAM: stap 3, afbeelding 1 van 2 Compaq Mini 110 Top Cover Replacement, RAM: stap 3, afbeelding 2 van 2
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
    Vraag FixBot
  4. Compaq Mini 110 Top Cover Replacement: stap 4, afbeelding 1 van 1
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
    Vraag FixBot
  5. Compaq Mini 110 Top Cover Replacement, Keyboard: stap 5, afbeelding 1 van 2 Compaq Mini 110 Top Cover Replacement, Keyboard: stap 5, afbeelding 2 van 2
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
    Vraag FixBot
  6. Compaq Mini 110 Top Cover Replacement: stap 6, afbeelding 1 van 2 Compaq Mini 110 Top Cover Replacement: stap 6, afbeelding 2 van 2
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
    Vraag FixBot
  7. Compaq Mini 110 Top Cover Replacement: stap 7, afbeelding 1 van 2 Compaq Mini 110 Top Cover Replacement: stap 7, afbeelding 2 van 2
    • Unscrew the screw for the bottom case located in the RAM compartment.
    Vraag FixBot
  8. Compaq Mini 110 Top Cover Replacement: stap 8, afbeelding 1 van 2 Compaq Mini 110 Top Cover Replacement: stap 8, afbeelding 2 van 2
    • Remove the three screws in the silver tabs at the back of the keyboard.
    • These are located at the back of the base under the screen.
    • Lift the keyboard away from the laptop.
    Vraag FixBot
  9. Compaq Mini 110 Top Cover Replacement, Hard Drive: stap 9, afbeelding 1 van 1
    • Remove the three screws holding the panel in place.
    Vraag FixBot
  10. Compaq Mini 110 Top Cover Replacement: stap 10, afbeelding 1 van 2 Compaq Mini 110 Top Cover Replacement: stap 10, afbeelding 2 van 2
    • Pull up on the tab to remove the hard drive.
    Vraag FixBot
  11. Compaq Mini 110 Top Cover Replacement, Top Cover: stap 11, afbeelding 1 van 1
    • Remove the eight screws that are from the plastic top cover.
    Vraag FixBot
  12. Compaq Mini 110 Top Cover Replacement: stap 12, afbeelding 1 van 3 Compaq Mini 110 Top Cover Replacement: stap 12, afbeelding 2 van 3 Compaq Mini 110 Top Cover Replacement: stap 12, afbeelding 3 van 3
    • Pry up the top plastic cover using a spudger.
    • These two tabs under the screen need to be pushed in with a spudger.
    Vraag FixBot
  13. Compaq Mini 110 Top Cover Replacement: stap 13, afbeelding 1 van 2 Compaq Mini 110 Top Cover Replacement: stap 13, afbeelding 2 van 2
    • Remove the cable by carefully pulling it up.
    • Be careful when lifting up the cover because the track pad is still attached.
    Vraag FixBot
Conclusie
4 andere personen hebben deze handleiding voltooid.
alea
1.429 Reputatie
14 handleidingen geschreven
Cal Poly, Team 22-2, Maness Fall 2010 Lid van Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 82
Altijd: 8,633
