Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Use this guide to access and replace your RAM. Assembly is reverse of disassembly. Consider utilizing an electrostatic discharge strap to protect components from damage. Disconnect all power sources and remove the battery pack before beginning this repair.
Wat je nodig hebt
Unscrew the two screws on the bottom of the laptop covering the memory compartment and remove the cover.
To reassemble your device(possibly install a new RAM), follow these instructions in reverse order.
3 andere personen hebben deze handleiding voltooid.
