Ga door naar hoofdinhoud
Compaq Mini 110 Keyboard Replacement
Wat je nodig hebt
  1. Compaq Mini 110 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 Compaq Mini 110 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
  2. Compaq Mini 110 Keyboard Replacement: stap 2, afbeelding 1 van 3 Compaq Mini 110 Keyboard Replacement: stap 2, afbeelding 2 van 3 Compaq Mini 110 Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Push both tabs inward simultaneously and slide the battery out.
  3. Compaq Mini 110 Keyboard Replacement, RAM: stap 3, afbeelding 1 van 2 Compaq Mini 110 Keyboard Replacement, RAM: stap 3, afbeelding 2 van 2
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
  4. Compaq Mini 110 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
  5. Compaq Mini 110 Keyboard Replacement, Keyboard: stap 5, afbeelding 1 van 2 Compaq Mini 110 Keyboard Replacement, Keyboard: stap 5, afbeelding 2 van 2
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
  6. Compaq Mini 110 Keyboard Replacement: stap 6, afbeelding 1 van 2 Compaq Mini 110 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
  7. Compaq Mini 110 Keyboard Replacement: stap 7, afbeelding 1 van 2 Compaq Mini 110 Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Unscrew the screw for the bottom case located in the RAM compartment.
  8. Compaq Mini 110 Keyboard Replacement: stap 8, afbeelding 1 van 2 Compaq Mini 110 Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Remove the three screws in the silver tabs at the back of the keyboard.
    • These are located at the back of the base under the screen.
    • Lift the keyboard away from the laptop.
Conclusie
4 andere personen hebben deze handleiding voltooid.
alea
1.429 Reputatie
14 handleidingen geschreven
Cal Poly, Team 22-2, Maness Fall 2010 Lid van Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Leden
20 handleidingen geschreven
3Gids Commentaar
hi, steps 5 and 6 are not needed. not sure about removing RAM either. If I look on my removed keyboard, all I see are three places for screws - those located nearby battery socket.
Petr Gebelt - Antwoord
I think steps 3,4,5,6,7 are not needed! The essential problem in removing the keyboard is not shown: how to lift the keyboard! Use the flat side or back of a screwdriver to push the metal strips shown in step 8 up (in the direction of the keyboard) to lift the keyboard. Put your fingers under the edge of the keyboard and pull gently but firmly. There is some resistance of the holding cover.
See also: https://www.youtube.com/watch?v=nELBz1VB...
Hans Donck - Antwoord
Thank you so much for the link!
Alex -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 33
Altijd: 17,037
