Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
A guide on how to remove the Top Cover.
  1. Turn the laptop bottom side up with the rear panel facing forward.
    • Turn the laptop bottom side up with the rear panel facing forward.
  2. Remove the two T8 Torx screws that secure the LED cover to the base enclosure.
    • Remove the two T8 Torx screws that secure the LED cover to the base enclosure.
  3. Turn the laptop top side up with the front facing forward. Open the screen.
    • Turn the laptop top side up with the front facing forward. Open the screen.
  4. Locate the F1 and F2 keys near the top left corner of the keyboard.
    • Locate the F1 and F2 keys near the top left corner of the keyboard.
  5. While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
    • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  6. Locate the Pause and Scroll keys near the top right corner of the keyboard.
    • Locate the Pause and Scroll keys near the top right corner of the keyboard.
  7. While holding the Pause and Scroll keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
    • While holding the Pause and Scroll keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  8. Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover. Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
    • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
  9. Lift the back edge of the keyboard and pull towards the screen.
    • Lift the back edge of the keyboard and pull towards the screen.
  10. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  11. Pull the cable and lift up to release.
    • Pull the cable and lift up to release.
  12. Remove the keyboard.
    • Remove the keyboard.
  13. Locate the fan near the top left corner. It has three colored wires: yellow, red, and black.
    • Locate the fan near the top left corner. It has three colored wires: yellow, red, and black.
    • Disconnect the cable connecting the fan to the system board.
  14. Locate and remove the four screws in the copper plate.
    • Locate and remove the four screws in the copper plate.
  15. Remove the heat spreader by pulling the whole assembly up out of the computer.
    • Remove the heat spreader by pulling the whole assembly up out of the computer.
  16. Flip the computer bottom side up with the rear facing forward.
    • Flip the computer bottom side up with the rear facing forward.
  17. Remove the six screws shown in picture.
    • Remove the six screws shown in picture.
  18. Remove battery and then remove screw in  metal support on case edge
    • Remove battery and then remove screw in metal support on case edge
    • Flip the computer top side up with the front facing you.
  19. Lift up the palm rest from the front edge and swing it towards the screen.
    • Lift up the palm rest from the front edge and swing it towards the screen.
  20. Locate the first connector. Disconnect by firmly pulling up.
    • Locate the first connector. Disconnect by firmly pulling up.
  21. Locate the second connector. Remove by firmly pulling up.
    • Locate the second connector. Remove by firmly pulling up.
  22. Remove the palm rest.
    • Remove the palm rest.
  23. Turn the base bottom side up.
    • Turn the base bottom side up.
  24. Remove the two TM 2.5mm x 8.0mm screws that secure the top cover to the base.
    • Remove the two TM 2.5mm x 8.0mm screws that secure the top cover to the base.
  25. Turn the base top side up with the front facing forward.
    • Turn the base top side up with the front facing forward.
  26. Remove the three TM 2.5 mm x 5.0 mm screws that secure the top cover to the base.
    • Remove the three TM 2.5 mm x 5.0 mm screws that secure the top cover to the base.
  27. Lift the top cover straight up about one inch, then slide forward until the microphone cable is exposed.
    • Lift the top cover straight up about one inch, then slide forward until the microphone cable is exposed.
    • Disconnect the microphone cable from the system board.
  28. Remove the top cover from the base.
    • Remove the top cover from the base.
Conclusie
Alex Hernandez
46 Reputatie
4 handleidingen geschreven
Cal Poly, Team 29-74, Johann Spring 2010 Lid van Cal Poly, Team 29-74, Johann Spring 2010
CPSU-JOHANN-S10S29G74
3 Leden
7 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 2,920
