Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Carefully remove the screws located inside the red circles.
Next, you will need to push down the "F1" key with the spudger and push it under the silver LED display panel.
Push down on the spudger to lift the LED display upward.
Do this on both the left and right sides of the device as shown in the images.
Completely remove the LED display panel from the device.
Lift the keyboard up from the back end as shown in the image.
Pull the keyboard slightly toward the screen of the device to reveal the connecting cable below.
Follow the cable to its connection and use the grip tweezers to unlock the cable by grabbing the left side of the lock and pulling upward.
Repeat this action on the right side of the lock.
Pull the keyboard upward to remove it from the device.
Remove the cable with the grip tweezers as shown in the photo.
Remove the rear fan.
Repeat these steps in reverse order to install the new rear fan.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
My Big Thanks! I cleaned the radiator, cooler greased and replaced the thermal grease from the CPU and GPU.
