Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Compaq Evo N1000v Rear Fan Replacement
Wat je nodig hebt
  1. Compaq Evo N1000v Rear Fan Replacement, Rear Fan: stap 1, afbeelding 1 van 1
    • Carefully remove the screws located inside the red circles.
  2. Compaq Evo N1000v Rear Fan Replacement: stap 2, afbeelding 1 van 2 Compaq Evo N1000v Rear Fan Replacement: stap 2, afbeelding 2 van 2
    • Next, you will need to push down the "F1" key with the spudger and push it under the silver LED display panel.
    • Push down on the spudger to lift the LED display upward.
    • Do this on both the left and right sides of the device as shown in the images.
  3. Compaq Evo N1000v Rear Fan Replacement: stap 3, afbeelding 1 van 1
    • Completely remove the LED display panel from the device.
  4. Compaq Evo N1000v Rear Fan Replacement: stap 4, afbeelding 1 van 1
    • Lift the keyboard up from the back end as shown in the image.
  5. Compaq Evo N1000v Rear Fan Replacement: stap 5, afbeelding 1 van 1
    • Pull the keyboard slightly toward the screen of the device to reveal the connecting cable below.
  6. Compaq Evo N1000v Rear Fan Replacement: stap 6, afbeelding 1 van 1
    • Follow the cable to its connection and use the grip tweezers to unlock the cable by grabbing the left side of the lock and pulling upward.
    • Repeat this action on the right side of the lock.
  7. Compaq Evo N1000v Rear Fan Replacement: stap 7, afbeelding 1 van 1
    • Pull the keyboard upward to remove it from the device.
  8. Compaq Evo N1000v Rear Fan Replacement: stap 8, afbeelding 1 van 1
    • Unscrew the 3 screws as shown in the photo.
  9. Compaq Evo N1000v Rear Fan Replacement: stap 9, afbeelding 1 van 1
    • Remove the cable with the grip tweezers as shown in the photo.
  10. Compaq Evo N1000v Rear Fan Replacement: stap 10, afbeelding 1 van 1
    • Remove the rear fan.
    • Repeat these steps in reverse order to install the new keyboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
ryan
470 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-1, Vijaybhaskar Spring 2014 Lid van UMass Dartmouth, Team 2-1, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S2G1
3 Leden
4 handleidingen geschreven
Één opmerking
My Big Thanks! I cleaned the radiator, cooler greased and replaced the thermal grease from the CPU and GPU.
DeK-Test New - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 396
