Ga door naar hoofdinhoud
Compaq Evo N1000v Palm Rest Replacement
Wat je nodig hebt
  1. Compaq Evo N1000v Palm Rest Replacement, LED Cover: stap 1, afbeelding 1 van 1
    • Flip the laptop over with the rear panel facing forward.
  2. Compaq Evo N1000v Palm Rest Replacement: stap 2, afbeelding 1 van 1
    • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
  3. Compaq Evo N1000v Palm Rest Replacement: stap 3, afbeelding 1 van 1
    • Flip the laptop back over with the front facing forward. Open the screen.
  4. Compaq Evo N1000v Palm Rest Replacement: stap 4, afbeelding 1 van 1
    • Locate the F1 and F2 keys near the top left corner of the keyboard.
  5. Compaq Evo N1000v Palm Rest Replacement: stap 5, afbeelding 1 van 1
    • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  6. Compaq Evo N1000v Palm Rest Replacement: stap 6, afbeelding 1 van 1
    • Locate the Scroll and Pause keys near the top right corner of the keyboard.
  7. Compaq Evo N1000v Palm Rest Replacement: stap 7, afbeelding 1 van 1
    • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  8. Compaq Evo N1000v Palm Rest Replacement: stap 8, afbeelding 1 van 2 Compaq Evo N1000v Palm Rest Replacement: stap 8, afbeelding 2 van 2
    • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
  9. Compaq Evo N1000v Palm Rest Replacement, Keyboard: stap 9, afbeelding 1 van 1
    • Lift the back edge of the keyboard and pull towards the screen.
  10. Compaq Evo N1000v Palm Rest Replacement: stap 10, afbeelding 1 van 1
    • Pull the cable and lift up to release.
  11. Compaq Evo N1000v Palm Rest Replacement: stap 11, afbeelding 1 van 1
    • Remove the keyboard.
  12. Compaq Evo N1000v Palm Rest Replacement, Palm Rest: stap 12, afbeelding 1 van 1
    • Close the laptop and flip it so the rear panel is facing up.
  13. Compaq Evo N1000v Palm Rest Replacement: stap 13, afbeelding 1 van 1
    • Using the TR8 Torx screwdriver, remove the six screws from the back case.
  14. Compaq Evo N1000v Palm Rest Replacement: stap 14, afbeelding 1 van 1
    • Remove the battery.
    • Remove the screw from the metal support on the case edge with a Torx T8 screwdriver.
    • Flip the laptop over again so the top is facing up.
    • Open the laptop screen and face it towards you.
  15. Compaq Evo N1000v Palm Rest Replacement: stap 15, afbeelding 1 van 1
    • Lift the the palm rest up from the front edge of the laptop and swing it towards the screen.
    • Be gentle as it is connected by some cables.
  16. Compaq Evo N1000v Palm Rest Replacement: stap 17, afbeelding 1 van 1
    • Disconnect the second ribbon cable.
  17. Compaq Evo N1000v Palm Rest Replacement: stap 18, afbeelding 1 van 1
    • Remove the palm rest.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alex Hernandez
46 Reputatie
4 handleidingen geschreven
Cal Poly, Team 29-74, Johann Spring 2010 Lid van Cal Poly, Team 29-74, Johann Spring 2010
CPSU-JOHANN-S10S29G74
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 3,100
