Inleiding
The Central Processing Unit (CPU) or Micro Processing Unit (MPU) is the 8-bit processor for the Commodore 64.
Wat je nodig hebt
Stap 1 Removing screws
Voorzichtig: stappen 1-2 komen van een handleiding die in bewerking is.
1. Remove three 6.75mm ph2 screw heads from the casing
1. Detach the multi-colored wire bundles connected to the motherboard.
3. Loosen the CPU chip with a Phillips screwdriver. Then use your hand to pry up the CPU chip from the motherboard.
5 andere personen hebben deze handleiding voltooid.
Één opmerking
there are two problems
1. Use an spudger for lifting the C.P.U instead of an screw driver bit to help alleviate concerns of bending the pins,
2. There is an step missing which involves cutting the tape seen here.
- Jordan .F
