Inleiding
A 3AG fuse is a glass - bodied fuse designed to break an electric circuit if the current exceeds safety levels in a Commodore 64 device
Wat je nodig hebt
Stap 1 Removing screws
Voorzichtig: stappen 1-2 komen van een handleiding die in bewerking is.
1. Remove three 6.75mm ph2 screw heads from the casing
1. Detach the multi-colored wire bundles that's connected to the motherboard
2. Find the 3AG fuse located next to the joystick ports and On/Off switch
3. Using the ifixit splugger, prop out the 3AG fuse from the clip.
4 andere personen hebben deze handleiding voltooid.
