Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Commodore 1341 Joystick te repareren, gebruik onze reparatiehandleidingen.
  1. Commodore 1341 Joystick Teardown, Commodore 1341 Joystick Teardown: stap 1, afbeelding 1 van 1
    • Introduced in 1984, the Commodore 1341 joystick was designed for use with the Commodore range of computers including the Commodore 64, 128, VIC20 and Commodore Plus4.
    • This joystick connects to the retro computers using a 9 pin connection.
  2. Commodore 1341 Joystick Teardown: stap 2, afbeelding 1 van 3 Commodore 1341 Joystick Teardown: stap 2, afbeelding 2 van 3 Commodore 1341 Joystick Teardown: stap 2, afbeelding 3 van 3
    • The joystick is held together by five phillips head screws. One screw is located on the handle and the remaining four are under the base.
    • Once the screws have been removed you can pry the case apart using a flat head screw driver. Just be careful with the base as it is spring loaded and it can fly apart quite easily.
  3. Commodore 1341 Joystick Teardown: stap 3, afbeelding 1 van 3 Commodore 1341 Joystick Teardown: stap 3, afbeelding 2 van 3 Commodore 1341 Joystick Teardown: stap 3, afbeelding 3 van 3
    • You will need to desolder the fire button cables from the board.
    • Pry the case open but watch for the spring. There is also a rubber bung that sits beneath the black rocker shaft.
    • Desolder the cables from the main joystick board and remove all of the components.
    • Now you are ready to clean all of the joystick components and reassemble.
Andy Marsh
118 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 7,010
