Ga door naar hoofdinhoud
Comment forcer le redémarrage de l'iPhone 8 Plus
Wat je nodig hebt
  1. Comment forcer le redémarrage de l'iPhone 8 Plus, Comment forcer le redémarrage de l'iPhone 8 Plus: stap 1, afbeelding 1 van 1
    • appuyez brièvement sur le bouton d’augmentation du volume (1)
    • Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
    • Il faut vraiment appuyer très brièvement
    The picture makes it look like you need to start this process with the phone turned on already, but I think you need to start with it powered off - that’s the only way that long-pressing the power button in Step 2 causes the Apple logo to appear.
    Owen Edwards - Antwoord
    For an iPhone 8, step #3 is to press and hold the right-side button. Continue holding the button down until the apple logo appears, then release.
    sjf - Antwoord
    what if the apple logo appears but nothing else happens. it just keeps showing the logo.
    LeRoyal - Antwoord
  2. Comment forcer le redémarrage de l'iPhone 8 Plus: stap 2, afbeelding 1 van 1
    • Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
    How can i have apple id and password to fix my phone
    Mhreteab Adresom - Antwoord
Eindstreep
70 andere personen hebben deze handleiding voltooid.
3 opmerkingen
What if my side power button doesn’t work?
Alex Busnelli - Antwoord
Are there any preconditions? Like should the iPhone be ON before step 1?
Are there any side effects? Like resetting momory, settings, etc?
Eric Bolinger - Antwoord
I pressed up volume button and lower volume button I don’t see anything
Ibrahim Ali - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 18
Afgelopen 7 dagen: 78
Afgelopen 30 dagen: 353
Altijd: 45,935
