Wat je nodig hebt
Appuyez brièvement sur le bouton d’augmentation du volume (1)
Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
Il faut vraiment appuyer très brièvement
Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
Und wenn das iPhone auf Tastendruck nicht reagiert?
39 andere personen hebben deze handleiding voltooid.
15 opmerkingen
Klappt - vielen Dank:-)))
This Worked! Thank You so much!
❤️Many thanks
Still not working
still didnt work
same im trying a million times and nothing
still not working
It worked perfectly!
still didnt work
help me please
Thank you! I have never had an app freeze like that.
der Tipp, nur ganz kurz zu drücken, war ausschlaggebend. Vielen Dank, Iphone wieder okay!
thank you it help me
Thank you for helping me.
Worked. Thanks alot
Thank you so much! This truly worked! We didn’t know what to do with my phone when it froze this was a life saver more importantly because customer service closed earlier! Thanks again
Marco Jackson - Antwoord
So my question is do you do this simultaneously?? Or one at a time?
jameciahardy - Antwoord
this worked, but had to do it a few times, phew ! Thanks
lise bourgeois - Antwoord
okay i see the coment everyone says it working but i pressed them down and nothing showed up .please respond
Ernest Toth 11 Clifton - Antwoord
i’ve done this many times nothing happens need phone traveling in the morning
kjmil54 - Antwoord
