Ga door naar hoofdinhoud
Comment forcer le redémarrage de l'iPhone X
Wat je nodig hebt
  1. Comment forcer le redémarrage de l'iPhone X, Comment forcer le redémarrage de l'iPhone X: stap 1, afbeelding 1 van 1
    • Appuyez brièvement sur le bouton d’augmentation du volume (1)
    • Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
    • Il faut vraiment appuyer très brièvement
  2. Comment forcer le redémarrage de l'iPhone X: stap 2, afbeelding 1 van 1
    • Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
    please what do i do when my iphone X shows Up the Itunes Sign and needs to be Reset ….. And please how do i reset it
    nana dollar - Antwoord
    I’ve been trying to restart my iPhone X since yesterday night… doing it the way I always do (volume up or down and hold side button) and NOTHING. I just came to look for help online and all the same thing. BUT I found your way… and I got my phone back!!!! It was frozen on the same screens, unresponsive. THANK YOU!!!
    Karina Ardizzi - Antwoord
    It didn’t work :(. I’m pressing the button….
    Susie Lopez - Antwoord
    how to know what happen with my iPhone X. dark only could not charge. I did not used a week.
    Bunyavasi Malherbe - Antwoord
    Nope... still frozen cycle....
    Candy Ogden - Antwoord
    Yay!! Finally found a simple and easy fix!! and it worked
    Deberah Blair - Antwoord
    Still pressing didn't show on
    akinyemi taiwo - Antwoord
    Merci beaucoup
    MBD - Antwoord
    Merci beaucoup. mais je une question par exemple si je veux regarder une vidéo je n'arrive pas pourquoi?
    MBD - Antwoord
Eindstreep
126 andere personen hebben deze handleiding voltooid.
13 opmerkingen
You saved my day. My iphoneX did not respond to anything after connect with the itune. I tried to shut down by holding volume up/down + side button but it didn’t work. So I tried your method and it worked!!! Thank you so much
Satit Jan - Antwoord
This is a temporary solution whenever my iphone gets unresponsive i used this method but after some time it again starts doing same laggy and unresponsive behaviour
Siraj Munir - Antwoord
good share. thanks.
MelissaR - Antwoord
What is the other way?
sa sas - Antwoord
will it delete all data from my iPhone?
_TR0xuu_ - Antwoord
No, it will only reboot the operating system. Your data and settings will persist.
Arno Keifl -
Génial. Ca a bien fonctionné même sur un Iphone 12
Emmanuel - Antwoord
Didn’t work. Now what?
Shawn Leimbach - Antwoord
It's not working for me, please anymore ideas?
Christiana Linus Ekpo - Antwoord
Apple logo didn't show on screen,just empty battery sign
May Weather - Antwoord
hi this literally saved my life thank you so so much!
bk03 - Antwoord
Face ID has stopped after changing the screen, how to fix
ALKAMBASHE EST - Antwoord
You have to have a machine that puts the old serial number on the new part so the phone recognizes it. It's called "parts pairing" and it's why Apple sucks. I have seen someone do it with an EEPROM reader/writer but I could not find one for purchase so you would need to go to an Apple-authorized repair tech to have your new parts reserialized.
Sandy Andlow -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 42
Afgelopen 7 dagen: 363
Afgelopen 30 dagen: 1,509
Altijd: 347,953
